Shutdown problem M1-ATX
  • Shutdown problem M1-ATX
    Here's the gist of it.
    Power - Direct to battery (Fused at battery of course)
    Ground - Run to metal bolt/bracket in car.
    12v Remote Line - Jimmy rigged to fusebox.
    Power button - set to hibernation
    My carPC is fun, fine and dandy. Problem is, I have the jumpers on the M1-ATX set to 5 sec/2 hour (Recommmended). I pull the key out of the ignition or off position and the CarPC shuts off as if I unplugged it with a regular PSU. I've checked the jumper twice today, and it is in the proper slot (#2). Checked all my wires, all working dandy.
    What could be causing the hibernation problem? I'm having to manually load it from hibernation each time I turn the PC on, or when I shut it down. Should I wire the remote line to the headunit remote line? I'm having a suspicious feeling that the remote line perhaps may be the issue.
    "Life doesn't forgive weakness."
    2001 Mitsubishi Galant ES - 5 Speed Conversion/KYB AGX/Tein S-Tech/Addco Rear Swaybar/Injen CAI/Megan Catback Exhaust
    CarPC [----------] 30% Complete
    Three-day bump.
