M2 powers up but doesn't shut down my motherboard.
  • M2 powers up but doesn't shut down my motherboard.
    I finally got to wiring my truck and was powering a test run. The motherboard turned on but when I turned my truck off the motherboard never shut down. This is a real problem. Is there anything I can do to fix this issue? I have a 2.0 GHZ Via C7 Jetway Mini ATX Motherboard. Any help would be greatly appreciated.
    CarPC - 90% Complete -Finally almost all done!
    http://http://www.mp3car.com/vbulletin/fabrication/97197-first-time-fab-2003-ford-explorer-please-help-lot-pictures.html
    Can someone help, I desperatly need it?
      sorry 4 the l8 reply but have u set it to "shutdown when u press the power button" in the "Power Options" in "control panel"
        Jetway boards are notorious for having problems with the M1/M2. has to do with how the front panel pin is shorted to turn it on.
        The M1/M2 doesnt short the pin, it just connects 1 of them to ground "simulating" a short. Some Jetway boards this doesnt work because the front panel pins arent the last stop on the circuit, so nothing happens when they are grounded.
        Basically, try this:
        Flip the 2pin connector going from the M1/M2 to the mobo on 1 end. Try it then. If that doesnt work, well you are pretty much screwed if everything is wired correctly.
        Try that first.
        1.9in x 2.9in -- 47mm x 73mm
