Wiriing question regarding m1-atx
  • Wiriing question regarding m1-atx
    I got everything connected in my car now but the m1-atx does not seem to be supplying power to my mobo as I get no fan spin or light.
    Is it safe to connect the ACC wire coming off the m1-atx directly to the positive(+) terminal to test if this is the problem?
    [HL]Warning - NSFW [/HL]
    yes, connecting the acc to the positive will make it turn on straight away, it wont be affected by the car being on or off.
      thanx a bunch. tried this but still nothing. next, I'll try wiring the ground wire straight to the neg battery terminal to see if I even get a spark.
      Getting late now and i'm looking at being awake over 24hrs lol. That monitor in my dash is looking sooo nice now. pity that I am having this problem now. the mobo worked fine when powered in the house with a standard atx power supply
        grounding it straight to the battery wont make any difference, check that you havn't blown the fuse on the m1-atx.
          got it fixed. YAY!!!. it was my ground wire. worked fine off the battery. I went back to the old spot where I had first grounded it and sanded off more of the paint. then reconnected it and everything works as expected.
