E-Vectra / M2-ATX - Applicability
  • E-Vectra / M2-ATX - Applicability
    Hi all,
    NooB here so I will admit to not knowing anyway enough so apologies for a basic question...I have however used the mighty search so bear with me
    I have just picked up a HP E-Vectra (free yay!)...I also have a M2-ATX PSU...now my question is, becuase the E-Vectra uses an external power-brick am I right to think that I cannot use the M2-ATX?
    Any help appreciated!
    Cheers
    Maz
    You are probably correct.
    You won't know without opening up the eVectra unit.
    It's very likely that a Carnetix P1900 or P2140 would work for your setup. What does the output voltage on the power brick say?
    How about the Wiki?
      thanks for the reply...
      the output voltage on the brick is 19V, 3.16A...pulling the box apart now...I am looking for a molex connection on the M/B?
        dang, doesnt look like it will work i really wanted the startup/shutdown features of the m2....o well back to the drawing board
          Ummmm.
          The Carnetix models that I called out have an integrated startup/shutdown controller as well...
          How about the Wiki?
