ATX Voltages
  • ATX Voltages
    I know most of the computer is run of the +12V, +5V, and +3.3V rails in the power supply.
    What voltage is used for what part of the computer?
    I would like to know so I can figure out how much current I need in each line in a DC-DC power supply.
    Are there any good resources on this?
    Thanks,
    Ben
    Re: ATX Voltages
    Ben
    yeah, a great resource is a search engine.. :P
    2 week temp ban (spam and complaining about deleted posts)
    register another account and you're gone for good.
      HMMMMMMM Ge that's a great way to help people...
      a good place to start is the manufacturer of each component of the pc motherboard, cpu, hard disk etc..
        The major ones are CPU, hard drives, and CD roms.
        You can get the rating for your CPU from the manufacturers web site. CDRoms and Hard drives have it on a printed label attatched to the drive. Then add about 3-4 amps for the rest of the electronics.
        CPUs using have their rating given in watts. So you will need to convert that figure into amps in order for it to be useful with the other figures. I think its something like Volts * Amps = watts?????
        (=========-) 99% complete
        AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
        All jammed in external CDROM drive case.
        Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
          just look around at other ATC power supplys and see what they rate at, like this one http://www.opussolutions.info/
          http://www.detz.net/detzbmw.jpg
