what would change the GND of my m2-atx to +12v???
  • what would change the GND of my m2-atx to +12v???
    This is what i get for tryin to clean up my wiring mess!!!
    i hooked my m2 back up the same way it was wired previously in my car and for some reason its shorting because the ground is reporting +12v!!! i tested this by hooking up my multimeter... each wire acts as normal except the ground (on J4 as its supposed to be). What the heck gives???
    Live mp3Car Facebook Chat
    well as probable as it sounds, a short.
    Make sure you didnt have a blonde moment somewhere and cross the wires. Also is the ground constant 12v, or switched?`
    1.9in x 2.9in -- 47mm x 73mm
      How are you measuring that the ground is +12V? Measurements are from a reference point, which is usually the ground. Your ground is +12V above what point?
      Gen 1: Pentium 3 1GHz - ATX - 2005
      Gen 2: Pentium M 1.6GHz - ITX - 2006
      Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
      Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
      ...it never ends
        Make sure the M2-atx is not sitting on a metal surface, the solder underneath it will cause it to short.
        I blew my fuse doing that
          no i never crossed the wires once. And the ground is constant 12v... as long as either of the other two pins (constant and remote) are receiving 12v the ground reports 12v.
          when i say +12V i mean 12 volts, not 0 volts, not -12v like when u reverse polarity on the multimeter. I hook the positive side of the meter to the GROUND pin on the m2 and the negative side to the battery ground... the meter goes up to 12volts.
          i never had that problem in my last case but the new case isnt constructed out of metal so that wouldnt be the problem. My fuse never blew when i attempted to connect the wires as they should be... there was just an electric charge at the connection point of the constant wire to the m2. No pops or smoke came from the unit itself
            If you're not blowing any fuses or releasing magic smoke then check for continuity between the M2 ground point and your ground test point. With an open circuit, the voltage drop across your high impedance meter would match the supply voltage.
            2004 4runner
              two potential answers
              1) you have a defective unit (either shipped that way or you broke it)
              2) you did not measure the voltage correctly
              TruckinMP3
              Read the FAQ!
                Another possibility: Your M2 ground isn't actually connected to the ground of the battery. There might be a disconnect somewhere.
                ...it never ends
                  I'll have to try that when i get home.
                  2) you did not measure the voltage correctly.
                  I know i've tested the voltage correctly... i've been doin car audio installs for 12 years. The unit might have been damaged somehow but i dunno how.. its been installed for over a year and working fine, then i just took it out over the weekend.. reinstalled it the same way it was before just a different case and boom.. problems. I also have an opus POL and a carnetix 5v and both of those work fine.
                  its definitely connected to the ground of the battery.. i took my auxilary battery out of the car and did a simple test hooking up only the three wires needed to power the psu... constant and remote were connected to +, then i tried to connect ground to - but same prob i had in the car... BZZZZZZZ as if its wired incorrectly. I guess the psu is just fried... damn shame!
                    Send it back to get fixed.
                    Maybe warranty maybe not. That is the next step.
                    TruckinMP3
                    Read the FAQ!
                      It definately sounds like you fried a chip then. When a regulator blows, it may sometimes just spew out what it is being fed. Not regulating. So basically a short circuit inside one of your chips. Any of them look burnt, or when you run it get really really hot?
                        Sounds like the PSU has a problem but something about this scenario is still troubling. If in the direct connect scenario above, the M2 ground point is measuring at the supply voltage, then you'd be dropping 12 volts over the ground wire. Assuming it's on the order of 1/10th of an ohm you'd be dumping 120A plus through that circuit. Unless you're using very large gauge wire, the wire itself should get fairly hot and release some smoke. Moreover the short-circuit path on the M2 itself should immediately begin smoking. Also, the act of connecting this circuit would cause a fairly sizeable spark (and likely shock).
                        2004 4runner
                          Maybe I'm just stuck in a rut, but I'm still confused at the ground part. You're saying there's a 12V drop from the ground of the M2 to the ground of the battery, and there's wires connecting it the whole way? Meaning there's a 12V drop over just wires? That kinda raises alarms in my head.
                          wires mean low resistance. 12volts over low resistance is high amperage, high power. If there's no current running from a 12v drop, then there's high resistance, like a break in the wires? Am I just off base here?
                          edit: typed too long, beat by rando.
                          ...it never ends
