power questions
  • power questions
    hi guys.
    I am just running around the web and trying to find out what the best power supply for the following specs would be.
    amb 1.2 ghz
    512mb ram
    20gb hdd
    I ran it to a cheap cig lighter invertor and it was not powerfull enough which i guessed would be the case.
    So I wanted to see if my battery would run the dam thing at all.
    I rigged some wiring which the ireing itself can handle to power but when I hooked it up to the battery nothing happened to the computer - nothing at all.
    For the temp setup to test if I would calling to much power I did the following.
    Wired an indoor extension cable from battery and had the computer on the floor next to my ride.
    then from the extension cord i spliced to a normal indoor three pin power cord - nothing happened.
    Any suggestions? I know the extension works as i did not mean to but touched the wires and they sparked. I even tried three diff PC's one was a crappy old P2 200mhz very low end unit.
    any suggestions to see if this will work - then the next question.
    Qhat kind psu do i do?
    1994 Jeep Grand Cherokee Laredo XP
    My CarPC Site
    1 - You're going to need to provide more details. "AMD 1.2Ghz" could mean quite a few different CPUs.
    2 - Read this thread: http://www.mp3car.com/vbulletin/showthread.php?t=68636
    It was written for pe9ople in your exact situation.
    How about the Wiki?
      urm its a AMD 2000+ if that helps Its one of the cheapy ones that says 2ghz but really only works out being 1200.
      reading your pasting threat now.
      cheers
      My CarPC Site
