How to get powerd up in car?
  • How to get powerd up in car?
    OK at the minute the power supply running to my computer which is going in the car is a standard one with a wall plug..
    How do i convert all this?
    Thanks shane
    use power inverter.
      You can use an inverter , or replace your PSU with any dc-dc vehicle PSU
      400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
      Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
        Or a DC/DC PSU like a Carnetix P2140, Opus , or other that will power your rig. See the FAQs
        Carputer Project Status:
        0% - Mobo died on 2/17/08
        Check out the worklog for my '01 Pathfinder.
          Usually I give advice raher than what I'm about to say:
          This really is a pretty basic knowledge which indicates you need to do a little research before continuing. There's reams of info on this site, take advantage of it by using the search button.
          I'll start off your quest with this though:
          DC-DC psu or if you really don't have much technical knowledge, inverter.
          If you're looking for a "what do I do" for everything, perhaps you should find a shop or someone to do it for you.
          Cheers
          BJ
          Leonardo Da Vinci
            i am not planing on asking continuous questions.... ive asked two.
            I will be finished as soon as i find a power inverter can anyone lead me to a good make?
              Plenty of people have used them with good and bad results. There is a lot of information on this site, you just have to look for it.
                Look for true sine wave inverters. Everything else is modified sine wave.
                true sine wave inverters produce ac current the same as what comes out of your wall socket.
                Google.
                They ain't cheap though......
                A modifed sine wave can work, it's just not he best option and can lead to noise.
                if you don't care about any of this, head on down to walmart (or whatever department store in your area). they'll all be modified sine wave though.
                Leonardo Da Vinci
                  here...check out the inverters here...
                  http://www.donrowe.com/inverters/puresine.html
                  Trouble deciding on car speakers? Clicky Clicky
                  Speakers: DLS Ultimate Iridium 6.3 Link
                  Subwoofer: removed
                  Amplifier#1 (Front Stage): DLS Ultimate A4
                  Amplifier#2 (Sub) removed
                  Carputer: Removed for tablet install
                    Is this a desktop or laptop?
                    If it's a laptop, just get the car adapter for it.
                    Leonardo Da Vinci
                      Thanks shane
                      Extension cord
                      ~Jimmy
                        http://cgi.ebay.co.uk/TBS-Victron-22...QQcmdZViewItem
                        Hows that? its a desktop i need to powere the desktop and the screen. i need uk plugs or maybe it doesnt mater.
                          Probably too small.
                          What's the specs on your desktop?
                          What kind of screen?
                          BJ
                          Leonardo Da Vinci
                            Originally posted by JimmyFitz View Post
                            Extension cord
                              Minimanshane,
                              Considering the lack of information you've provided, there's no way to offer anything byut generalized suggestions.
                              Those that uggested you search the forums are probably the best ones at this point. There is a wealth of information here that will aid you in your project. However it's not going to just jump at you to be held, read and studied. You've got to find it yourself, and sometimes you have to wade through a lot of crap to find what you need.
                              However, the information is there. Go get it.
                              How about the Wiki?
