Do i need an "intelligent" psu?
  • Do i need an "intelligent" psu?
    Not quite sure how to name the title
    Basically, im in the process of building my carputer, and was looking to buy a m2-atx.
    As ive kept my headunit in my fabrication (radio/cd for short journeys) i dont want the pc to start auto. I want to place a power button to start it manually. But i do want an auto shutdown feature with turning off the ignition
    The question is: Do i need an "intelligent psu" like the m2-atx / opus etc. Is there a cheaper alternative as i only want the shutdown controller?
    thanks
    Worklog: http://www.mp3car.com/vbulletin/work...-ibiza-uk.html
    shutdown is part of the intelligent bit so yes you do have to if you want a shutdown controller. You could also use your button to shut it down of course but that isn't auto. What car power supply you could use that doesn't have a controller I have no idea.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
      You have a lot of options
      Easiest is a Startup/Shutdown controller with a switch on the ign/acc signal.
      You could control the psu with an instantaneous switch that is latched by the Ign/Acc signal. To do this you need some knowledge of /access to simple relay circuits.
