suggest a PSU
  • suggest a PSU
    I've got the jetway AMD 1.4 geode board, the CF/PCMCIA card daughterboard, an SATA HHD and I'll want to power an LCD touchscreen and a few USB devices such as a GPS receiver. I'm budgeted to keep my PSU under $100. The M2 was my choice but I'm hearing a lot on negatives on here. The carnetix and opus sound good, which of those three would you guys suggest? If I had $200 I'd just get the DSATX.
    OPUS or DSATX
    Save until you can get the one that fits your need. If you already know the one you want, anything short of that will make you less happy.
    This is an entertaining hobby, (not a need/requirement) buy the right gear the first time and avoid the double spend of replacing it later.
    TruckinMP3
    Read the FAQ!
      http://www.mp3car.com/vbulletin/advf...iew&advfaqid=3
      Should help you out some as well.
      Jan Bennett
        Bought the DSATX and got Streetdeck @ $100 off, nice.
          Sounds like a good solution.
          TruckinMP3
          Read the FAQ!
