DS-ATX : Just installed, not behaving correctly
  • DS-ATX : Just installed, not behaving correctly
    When I start the ignition, the power supply starts the motherboard for a second, then cuts power causing the fans to stops. They don't even get a rotation. The light on the power supply is a solid red and the motherboard is getting some power to it as the LAN adapter shows an orange light on the motherboard and the CDRW/DVD-Rom is blinking.
    I'm using an MB896 board from iBase. I believe this is the same or similar to the one Red GTI v6 is using.
    Any clues of what I should look for to help with this issue?
    Software Developed:
    DS-ATX Controller Interface
    Laptop Shutdown Controller
    Considered Projects:
    TPMS Interface
    Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
    Try just powering the motherboard, no hdd, or dvdrom, nothing but the mobo. Sounds like the PSU is overloaded.
      I will definitly give that a shot. I only have the harddrive, dvd-rom, and a wireless card plugged into the mini-pci slot. This power supply should be able to handle that easily.
      Software Developed:
      TPMS Interface
        You might also try powering the whole ball of wax with a standard-issue ATX power supply, just to make certian that everything is in working order.
        How about the Wiki?
          Yeah, that's sounds like a good plan too. It was working on the bench before I installed it.
          Software Developed:
          TPMS Interface
            ok my bet is you are either not using a 4 PIN p4 cable and your mobo requires that..or you mobo has a reversed polarity turn on switch
              Definitly somthing good to check. My motherboard does not have the 4 pin plug on it and I have tried the power switch in both directions. But still good ideas!
              Software Developed:
              TPMS Interface
                Here is an image of the motherboard.
                Software Developed:
                TPMS Interface
                  r u sure that the 4pin thingy on the right of the ATX power connector is not the 4pin P4 connector!!!??? because i am 99.9% it is...
                    There is a P4 4pin connector there!
                    Its touching the main PSU connector
                      Here's the manual : https://www.technoland.com/Manuals/MB89610a.pdf
                      The ATX_12V connector is documented on page 17 (page 21 of the pdf).
                      Manuals are good, m'kay...!
                        looks like i win the bet
                          You are right, it does look like the connector is on the motherboard in that picture. When I go grab some lunch, I'll check it out. Maybe this picture isn't accurate.
                          Obviously, I didn't closly look at the picture before I posted it.
                          Software Developed:
                          TPMS Interface
                            I just went down to the car, looks like the picture is inaccurate. I'll post the picture of MY motherboard when I can get to a mini-USB cable. Everything appears to be accurate except the P4 power connector. On the bench the system ran fine without plugging in a P4 power connector.
                            Software Developed:
                            TPMS Interface
                              yeah i missed that on your post..this is something else then
