AOpen MiniPC + M2-ATX?
  • AOpen MiniPC + M2-ATX?
    I was wondering if the M2-ATX will work with the AOpen MiniPC? Most people that I've been reading on, have used the CNX 1900. Is that the only one that will work? Or is the 1900 better anyways?
    The m2-atx or similar supply will not work, the only option is the carnetix p1900 or p2140.
      okay..thanks..so im guessin the p1900 is the one similar to the m2-atx
        No. They are very different.
        The M2ATX is an ATX-compatible power supply.
        The Carnetic P1900 is a regulator/convertor that supplies a single output voltage for mini PCs.
        How about the Wiki?
          actually, what i meant was its similar as in specs..what it can do
