pc using a lot of power when shut down
  • pc using a lot of power when shut down
    Hi,
    i have a problem: when my pc is shutdown, it uses so much power, that it drains my battery.
    i measured it, and when i plug in the fuse from my pc, it uses 0.5A (6watt) when it's shut down...
    what can the problem be? I never had this before, it started a week ago...
    can it be that some usb devices keep using power when my pc is shut down or in standby (or hibernated)? can that be the problem? or is it something else? i recently connected my dvd drive via usb instead of ide (with an ide to usb convertor), but the power for that is comming from a regular molex, so there is no power on that when pc is off...
    Greetz
    Dj NRG
    Have you tried measuring the current draw after unplugging all USB devices?
    Jan Bennett
      not yet...
      battery was too empty
      will charge it tonight, and measure it tomorrow...
      i'll let you know what it says...
      Greetz
      Dj NRG
        i am interesting in it too. What type of power supply do you use ?
        400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
        Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
          opus 150 watt...
          Greetz
          Dj NRG
            ok, so i got to measure things...
            when my pc is shut down completly, and all usb devices are plugged out, my pc eats 1.2watt. when my usb cables are plugged in (steering wheel control, touchscreen, usb dvd drive (all 3 over a hub) and external soundcard), my pc eats about 4.8 watt!
            what sould a pc normally use when completly shut down? 'coz i think 1.2 watt is also quite much. and what should it use when in hibernation /standby? and can i change some setting (in bios or somewhere) to feed no power to my isb devices when pc in out (shut down, hibernated, standby)
            a lot of question, i know... hope to get the same amount of answers
            Greetz
            Dj NRG
              Yes, at least in my BIOS, there's a setting to shut down USB in Standby (S3) mode.
              Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
