Inverter+AuxBattery+CRANK Survival
  • Inverter+AuxBattery+CRANK Survival
    I am bad at calculations...I would be using a 12volts 7Ah Sealed Lead Acid Battery
    with the following specs:
    Charging perimeters:
    Constant Voltage Charge with voltage regulator (27 degrees celcius)
    Standby use: 13.6V - 13.8V
    Cycle use: 14.1V-14.4V
    Max. Initial Current: 1.4A
    kindly help i want to build a tank circuit also please confirm if a tank circuit would ensure that my inverter does not malfunction during cranking!! thanks guys
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
    300W DC to AC Inverter
    ::FRONTEND:: I need suggestions please
    ::OPERATING SYSTEM:: TinyXP
