Wich DC=>DC PSU to build ?
  • Wich DC=>DC PSU to build ?
    Hi ,
    I finally decidet to build a DC=>DC Power Supply.( Major cause is that I have noise on my S-video TFT.)
    But know the question is : What to build ??
    Sproggy , Felix Richters's V2 PSU or another.
    Which one is the best, cheapest and are there other good ones ?
    Also a point is that I live in Europe and i saw several times that people in Europe have prob's to get the coilcraft parts for The sproggy .
    So anyone with a solution (oppinion) for me ?
    Many Thanks
    Felix
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    If you have enough room for a "normal" ATX PSU, and aren't afraid of doing some heavy thinking I would suggest a presslab conversion. I love it cost me quite sometime to get it working the way I wanted (correctly ) In all it cost me about 20 Euro and an old ATX PSU (welll two actually and a AT, I first tried one ATX but I lost my notes during moving so I started again with a AT to see if it really worked before buying another ATX)
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
      Still got that AT ?
      Marsjell !
      Do you still have this converted AT -supply
      I might need one !
      Let me know !
      Greetz
      Raas - The Netherlands
      ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
      GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
        Hi marsjell ,
        Many thanks for your reply.
        I have the room but i'd prefer a kind of "long" one or If the high is lower than on a normal psu. it's because i want to integrate it in my plexi case.
        (see automp3.de 2 give u an idea how many place there's in the case).
        tnx
        Felix
          Raas,
          like arby, I also reused my primary side of the AT version... if you like I could build a new prim.side circuit, I'm not sure but I think I still have the rewound transformer & secondary side lying around so all I need for a working AT is the prim. side
          I don't have a lot of time on my hands so it would take quite some time, or if you like I could send you the transformer & sec. side so all you have to do is solder the circuit which isn't difficult.
          let me know!
            Marsjell,
            I'm very happy we can work something out !
            What do I need else if you would send me the (modified?) transformer and sec.side ?
            I have a bunch of old supplies lying around here.
            TIA
            Greetz,
              Hey Felix, I just remembered an url (I'm sick I know....)
              http://www.richterfelix.de/netzteil/
              this was mend for you!!!
              1) in german (your preffered language right?)
              2) www.richterFELIX.de/netzteil!!!!
              I can't imagine something suiting you better
                /Off-topic/
                Felix,
                I noticed that you're using a KNC-1 radio/TV card,
                how are you using this? I'm trying to hack into the card and so far I can only readout all the RDS data (RDS, RDStext, and stationinfo), but I just can't find out how to readout the frequency-info, so when I search manually I can't see which station I'm listening to if it doesn't have a clear RDStext or worse, when I'm looking for a specific station, I have no clue where I am( frequency that is )
                cheers
                  I use the card only for TV and it's not the RDS card
                  -Sorry-
                  But like it has WDM driver you should normally be able to get the freq-infos via this . I'm not a programmer.
                  Another possibility is to write to KC-one and ask. I did the experience that if you get the right person you can get all info you want
                  On the RDS - ( AF ) info you should also get the actual frequency if my memory about RDS specs is good.
                  Are you coding yourself an app ? if yes would it be freeware ?
                  Felix
