Fuse
  • Fuse
    What size fuse should I use between my battery and dc power supply?
    depends...
    What power supply will you be using? Look in the manual for it to determine the amperage needed. That will also be a consideration as to what size wire to run.
    See the FAQ's, specifically this one:
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=5
    ~Jimmy
      I am using a OPUS 250W/320W Intelligent DC-DC PSU, but nowhere in the supplied literature does it state the amperage.
        P = V x I
        [Watts] = [Volts] x [Amps]
        1.9in x 2.9in -- 47mm x 73mm
          Thanks for all the input. The answer I came up with was 15 amp. Does that sound correct?
            250W is 20A and 320W is 27A. You dont have a 250W/320W you have one or the other.
            And usually you take 115% of the value.
              how do I know which wattage it is, because the description says both?
                The description is for both. But when you order, there is a dropdown for the 320W for additional money. Obviously you dont pay the same price for more wattage. You should know what you buy.
