+12 and ground from harness to m2-atx
  • +12 and ground from harness to m2-atx
    I have just changed cars and I am going to install my old carputer into my new vehicle.
    I have a CANbus adapter that has 2x(+12) and 2x ground coming from it.
    Im going to use one set for the headunit and was wondering if the m2-atx would function ok if I used the other set to power it?
    Im not too bothered if it cant work but i am locating the pc under the passenger seat and the wire run would be shorter if it would work.
    How much power can this adapter provide? It doesn't sound like something designed to supply enough power for a computer or a headunit. A standard headunit and the m2-atx should both run off automotive +12, so they don't need power conditioning or regulating by some other box that may not be up to the task of providing enough current. I'd just put in a decent power distribution setup with adequate wire sizes, fuses, etc.
      its a pac c2r-chyna and is designed for stereo replacement but I just dont get whey they would include 2x (+12) on a stereo harness.
        I guess I was thinking of something else when you said adapter. I don't understand enough about what a c2r-chyna does from a quick look on the web to tell if what you want to do will work. Hopefully someone else knows more than I do.
        I'm still pretty skeptical that you'd want to power your computer with it even if those are intended to supply power to something since the m2-atx will draw 13+ amps if its delivering full power so you want a good power source. If the adapter is supposed to allow you connect a head unit to it for power, then that shouldn't be a problem if they designed it for that.
