wanna develop own 12V PSU(some Questions)
  • wanna develop own 12V PSU(some Questions)
    between my exams I got crazy and know I have the idea of building my own 12V Power supply for my player .
    But ther are some few questions I have o get answered before:
    - Do I really need -12V and -5 V?( If yes why and for what)
    - How much Watt's does it have to have in general and how much on each Volatge ?
    - Are there delays to respect ?( for example that 5V has to switch on after 12V or such a thing)
    -What about max tolerances for the Voltages
    - Anything other to respect ?
    - Do i really need powergood and what is it for ?
    - What about input voltage (is 8-15V enough?[just to know i didn begin planning])
    -could i drive drives and Motherboard by different PSU's (PSU circuits )
    - Any helping links FAQ's or such?
    Many tanks
    [edited because pressed enter during writing]
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc:: :: CAR= Renault Clio2 - 2 seats 1.9D
    1. -12volts is often used for serial ports.. don't think you need -5volts
    2. 10amps @5volts
    10amps @ 3.3volts
    5amps @ 12volts
    should power a moderate system
    3. The powergood signal, which is 5volts or 3.3 for ATX (either can be used, I think) which is just a slightly delayed power on... (look at sproggys for a simple circuit to get this..)
    4. probably +-10%
    5. Efficiency....?? maybe....
    6. some older, and possibly newer mobos won't boot without it...
    7. 8-16 is the standard, but if you can covering upto 30 or so would be good (people might wanna use it in a bus or something)
    8. Sure, but why???
    2 week temp ban (spam and complaining about deleted posts)
    register another account and you're gone for good.
      Hi just wanted to add that :
      -you need the -5V if you have soundcard with a build in amp (most do)
      -powergood can be done with a simple RC-network (check my website)
      If at first you don't succeed.........
      destroy all evidence you tried
      for info on t6369c LCD or Presslab's powersupply check: <=updated!!
