Help DC to DC
  • Help DC to DC
    I would like to set up following computer in my Truck, but i am having hard time finding power supply. I need help finding power supply for following computer.
    I would like to keep this system and replace power supply with DC to DC.
    Info on my computer.
    Dell™ OptiPlex™ GX260 Systems
    small form-factor computer: 160 W
    Heat dissipation
    small form-factor computer: 455 BTU/hr (average)
    90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz
    Full Info on PC
    I have a gx (280) series as well I like to also find out what type will work well.
      D201GLY2, DC-DC power, 3.5 inch SATA
      Yes, you should search... and Yes, It has been covered before!
      Read the FAQ!
        If you have a computer with you, you have to open the case and look at the label on the PSU.
        What is the ampage rating on the PSU for 3.3V, 5.0V, 12V ?
        Once you have that info, compare it to any of the available DC-DC PSU. The DC-DC PSU you select must have ampage rating of equal or higher than of the AC PSU on ALL power rail (output voltage).
        Total wattage of the system doesn't tell you much. It is the same thing as saying "this computer run on AC"
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
