installing a powered USB Hub.....questions?
  • installing a powered USB Hub.....questions?
    Hi guys,
    Im goign to be installing a powered USB Hub. Searched around and saw a device that can be used to convert the 12V to 5V, but it seems like it only worked with a certain power supply. If i found the 5V wire coming off of my PSU, if i tapped into that, would that work just as good?
    thanks in advance
    would work just fine
    Jan Bennett
      sweet, thanks!!
