PSU Selection Confirmation
  • PSU Selection Confirmation
    I try not to post without searching, and I believe I figured the power consumption out:
    I purchased an AMD X2 BE-2300 (45) processor.
    I will be using two case fans, and a 3.5" hard drive.
    From reading, all of these pull from the 12v line. USBs pull from the 5v.
    So, rough calculations:
    45w, 2x 5w, 20w (hard drive is the 20w, and from charts is rounded up)
    So, I should need at least a 75w 12v line, and the M2-ATX provides 8a on the 12v line, which is 96w.
    The 5v line will be supplying 5-6 USB devices, which is up to 30w total. The 5v line provides 8a, which should be 40w max.
    So from these numbers, am I correct that the m2-atx should do just fine?
    I was about to pull the trigger on the DSATX+brainstem which was $180.xx with shipping from mp3car, but if I can save $100 as it's "not needed", then that's the way to go.
    Any confirmations are appreciated!
    (by the way...I could be way off on everything!)
    Edit:
    I forgot about the monitor...
    About 10w, and pulls off the 12v as well? If so, that would be pushing it a tad (if I'm even correct)
    Screw it, got the DSATX+brainstem!
    Hopefully it ships out soon like everything else I ordered from everywhere else!
      Good choice.
      1.9in x 2.9in -- 47mm x 73mm
