M2-ATX 4-pin configuration...
  • M2-ATX 4-pin configuration...
    Does anyone happen to know the pin configuration for the 4-pin plug on the M2-ATX?
    I just want to double check.
    I've got it as 2 - 12v and 2 - grounds.
    However, the standard for the 24pin says it's not like that...standard says it's one of each (12, 5, 3.3, ground).
    The 4-pin extension doesn't line up when plugging it in. The rounded pins and the square pins don't line up on the mobo side if you leave the clip facing the same way as the 20 pin ATX connector.
    This is a J9F2 mobo fwiw.
    Jan Bennett
    The 4-pin on the M2 is a so-called "4-pin P4 connector", or something like that. It is for plugging into a separate header on the motherboard, not the 24pin bit. You're right, it's not the same as the ATX bit.
    You're mobo should power from just 20 ATX pins - if not, just get an adapter.
      The adapter though just splits the signal, and to be ATX compliant, all 24pin motherboards should boot with a 20pin PSU. It just wont have all the power it wants. So if you are running a super hungry CPU, it may cause problems, but most motherboards will automatically regulate it now so the CPU will run in "mobile" mode and not go to full potential basically.
      Those 4 extra on the 24pin from the 20 pin is the P4 x4 cable equivalent of today, but not interchangeable.
      By the way, what ever happened to the 8pin extra power header? Those came and went fast. I only saw them on P4 Extreme Edition boards, and never again! I have so many of those damn cables and no use
      1.9in x 2.9in -- 47mm x 73mm
        Thanks for the info guy. Running a mobile core 2 duo so it's not a power hungry processor. Will just leave it as is!
        Thanks. Searched online for a while and couldn't find anything diffinitive.
        Jan Bennett
          ...come on I'm right around the corner, and would love to see the new pad.
          Setup:
          Dynaudio 240GT
          PPI PC4100, PPI PC2350
          Zapco DSP6
          ADS DAC
          Testing new board (Albatron KI690-AM2)
          "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
            Just let me know when!
            Jan Bennett
              I also have the same question hope you don't mind I jam in.
              how do I connect the 20 pins to 24 pins header? I am using Asus and Celeron 1.8. do I need to connect the 4 pins cable to 4 pins header as well? Thanks
                Just plug the 20pin cable into one end of the 24pin header and see if it works.
                  Thanks for reply, can somebody kindly tell me which side I should plug in, left or right from the clip as for the top.
                    You should only be able to plug it into one side.
                    If you can plug it into both, something is very wrong
                      Thanks again, okay, if you look at the socket on mb, the little clip face it upward as for reference, to connect to this socket, do I leave 4 empty pins on left or on the right of the socket. Thanks
                        HELP! Newbie here, Can someone tell me if i am doing this wrong? I have the power, switch, and ground hooked up correctly. My motherboard requires me to have the P4 cable installed, when i go and plug my P4 cable into my M2 then into my MB the only thing that moves is my chassie fan and only a little bit back and forth. Kind of like it is out of power! But if I unplug the P4 cable from the MB and turn it back on, the PC now turns on strong! But does not boot. (THIS ALSO HAPPENS ON MY REGULAR ATX POWER SUPPLY WHEN I DON'T HAVE THE P4 PLUGGED INTO THE MB).
                        Kind a makes me think I am drawing to much power for this little M2 to handel, but the kicker here is, it is 160watts of power and I don't have any other power being used other then my fans, unless my radeon 9600 is using up more power then i would think.
                        Can someone please help, i can't be the only one with this problem, right?
                        Thank you Phil from Chicago IL.
