m3 software for custom times
  • m3 software for custom times
    does anyone have the software to program the m3 for custom times? also where does the serial cable plug in?
    Does ANYONE know how to set these "custom" shutdown settnig for the m3-atx???
    In the manual it says you can ..but how
    10 acura TL tech
    10 BMW S1000RR
      You have to have the software and a serial cable to re-program the m3 atx.
      Car Pc progress meter:
      [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
      "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
      My worklog
        I just bought one. It came in today brand new but there is no software or cable...
        where do i get that?
        10 acura TL tech
        10 BMW S1000RR
          ok i found out on my own...
          you need this "serial" cable and software you can find here.
          cable - http://www.mini-box.com/Serial-Cable-Harness-M3-ATX
          software - http://www.mini-box.com/site/resourc...ATX-serial.zip
          10 acura TL tech
          10 BMW S1000RR
            Doesn't matter since it doesn't work anyway.
              I got it working after emailing with Mini-Box tech support. On my motherboard (MSI IM-GM45) the com port header's pin layout is not the same as the M3 cable (why aren't their standards?!), and they thought I might have fried the M3. But after adjusting the wires, I was shocked to see it get detected.
              Unfortunately, the maximum hard-off time you can set is 18 hours (I was hoping for 36-48 hours).
              Here is the M3 documentation that shows the cable's wiring:
              http://www.mini-box.com/site/resourc...20Type%201.pdf
              You have to find your motherboard's manual and see what its com port header's layout is. Here's a screenshot with the layout for my MSI IM-GM45 motherboard:
              And here's the M3 cable's layout (red=receive, white=transmit, and black=ground):
                I ended up frying one because the diagram on their website had the send and receive pins switched....glad to see you got it working though.
                openMobile - An open source C# Front End (why choose openMobile?)
                - Always Recruiting Developers -
                Like what you see? Donations are always welcome
