DC Input AC output using MPI-400
  • DC Input AC output using MPI-400
    Hello,
    I am in the process of building my carputer. I am using a laptop after removing my screen. Is it possible or advisable to use MPI 400 (see specs below) insead of using something like Carnetix. Thanks in advance for the replies.
    (400w Constant Power w/ 800w Peak
    12v DC Input & 110 AC Output
    Direct Battery Connection
    Two 3-Prong Standard Receptacle
    Over / Under Input Voltage Alarm Protection
    Output Short Circuit Protection
    Thermal Protection, Built in Fan Cooling System )
    MPI 400 scroll down to see the hardware.
    for a laptop most people use a DC to DC converter for automotive use. Much less waste compared to a conversion of DC to AC and back to DC.
    TruckinMP3
    Read the FAQ!
