DSATX 5 blinks.....
  • DSATX 5 blinks.....
    Hey everyone (and Jeff), I've had the DSATX for a long while now without any problems. Now, out of the blue I've been having problems. Whenever I supply ACC the red light goes on for a couple of seconds, then goes into a fault - 5 blinks. I measured 11.8 volts at +VIN and at ACC. I have pulled the fuse to reset it numerous times and got the same results.
    I was going to hook my brainstem up but for the life of me I can't find it anywhere!
    I noticed I have a firmware version D894805. Can this be the problem that it has the older firmware that needs updated?
    Thanks for your help!
    Dan
    1997 Corvette
    I have recently had the same issue. I dont have too much electrical knowledge so i havent done as much testing but just happened out of the blue. I have tried disconnecting all cables and reconnecting but to no avail.
    I see you mentioned your firmware version. How can I check my firmware to see if its the same? If that will even help?
    Cheers
      Dan
      Yup 4805 problem of death.
      You need to send it back to me and I'll update it for free.
      PM me.
      -Jeff
      MPEGBOX - Plexiglass Computer
      www.mpegbox.com
        @zootjeff:
        Can you perhaps help me?? I do not get my Brainstem correctly for running. Once I could with hyperterminals connect, but after some conversions my DSATX does not start correctly as soon as the Brainstem is connected. If I it do not attach function it in the best way. How do I know all shutdown times reset on factory setting?
        My Project: German/English
