DSATX w/brainstem Problem
  • DSATX w/brainstem Problem
    I have recently purchased the dsatx and brainstem.
    I am bench testing everything right now, so here is my setup for the dsatx:
    - Similating atx power by jumping pins 13/14 on atx power supply.
    - Attached a switch from acc on dsatx to 12v on molex
    - ground from a molex
    - running vin to 12v molex
    When i power up the dsatx it seems i never hit post. I get it to boot up probably once every 10 times. Everytime i boot from the dsatx a solid red lite is on and then i get no vga signal on my monitor.
    I tried it on another computer and boots up fine with vga everytime. So, looks to be a problem with compatibility with my motherboard and the dsatx or something. I am using a MSI motherboard running an amd xp processor.
    Also, with the brainstem hooked in i get a solid led, but when i give it power the dsatx doesn't get power it seems, no blinks nothing. When i disconnect the brainstem the dsatx boots up fine.
    I know i have it in the right way, bucasue if i put it in the otherway the led flickers and doesn't get reconize on startup, but am able to boot.
    Maybe i hot plugged the brainstem and need to reset it, which i havent' done yet, but wondering if i'm doing something or maybe its my motherboard. Even if i did hot plug the brainstem, shouldn't it still boot and just act weird?
    Just wondering if anyone has experienced this with either situations above?
    Also, i have tried 3 atx power supplied to similate power, but i could only get one of the atx psu to works. With the other 2 the dsatx doesn't get power which is weird. I used a volt meter to test the volts on the psu that worked, so will test the other 2. Thought that was weird..
    blair.
    blair.
    You also need to short\jump pins 8/9 on the ATX PSU.
    Zerach
    CentraSkin Developer
    Try out the new version of CentraSkin V.52
    Click here to get CentraSkin V.52
      I have a problem with the Brainstem adapter. If I it to the DSATX do not attach start my PC any longer correctly. It starts, goes out however equivalent again. And the LED of the DSATX flashes 4 or 5 times. What does that lie?? If I the Brainstem do not attach function everything normally. A RESET I made, it help also not.
      My Project: German/English
        i had the brainstem on com 3 and it worked reasably wel. Because of a new position of the mobo, now i use com 2 and when i switch to the gps program, al power goes.
        I use a m2 to power the harddisk and the powerd usb-hubs, so its not that it needs to put out more power than it can handle.
        But my gps (usb) recever takes com3 in cpc. So what i think is that maybe the irq adres has somthing to do with the switching of.
        I have changed the irq to the on i use on the com 4, probebly test it this weekend.
        Cold weather mobo list: Copy the list and add your board
        my hidden screen in action (youtube) , the worklog , RR Volvoskin
          I think the ATMega88 am defective. Can one exchange so simply and again program??
