LV-671 and M2-ATX
  • LV-671 and M2-ATX
    Hi all,
    I just have an LV-671 motherboard but there is no ATX connector on it only a P4 connector.
    How can I use my M2-atx to power this.
    And what do I need to have the M2 power it on when i start engine.
    Thanks in Advance
    Chris
    You need 12v regulated power. The M2ATX is an ATX power supply.
    I would see if you could possibly exchange it from the vendor for what you really need.
    How about the Wiki?
      But there seems to be people here that have succeed with m2-atx and this motherboard.
      If no what do I have to buy?
        Re: > LV-671 and M2-ATX
        If you use an M2-ATX, you'll have to make a switch yourself from the ATX Pin 14 (PS_ON) and ground (COM, e.g. pin 15) to start the power supply on the large ATX connector.
        However, you can also use either any 60W+ 12V OR 19V regulated supply.
        I myself have soldered a standard Cylindrical Power-in plug to a 4Pin ATX (processor) plug, and plugged that into the 4pin on-board ATX connector. This is officially 12V, but since it is directly coupled to the external 4pin DIN socket ( I ohmed it out) it will take any normal 19V as well. Saves a lot of searching for the 4-pin DIN connector the Commell people put on the motherboard....
        So the cheapest option is: 4-pin plug from an old broken ATX, standard cylindrical power-in from anywhere soldered to the 4Pin ATX, use generic 19V/20V car Laptop power supply. Just check polarity carefully.(RTFM...)
        Works like a charm, and is a lot cheaper. Also means that you can easily test off-car with a cheaply bought second hand mains to 19V Compaq/HP/Dell/what have you. I picked a few off unused 60W spares off the street recently from a cardboard box(yes, really, meant for the garbage collector...) - they don't come any cheaper.
