DSATX Brainstem pinout
  • DSATX Brainstem pinout
    Couldn't find this anywhere by searching. I need to know what pins are being used by the serial port of the brainstem. I'm assuming its only 4 pins, but I just need to know which pins those are.
    Found one here........
    http://www.acroname.com/robotics/par...-INT-CONN.html
    If anyone gives me a rev - I give them the Bird
      Actually that still doesn't answer my question - I already know what the DSATX side of the Brainstem pinout is - I need the serial side of it.
      HOWEVER, that link you posted has an item that will work for what I need - I needed an extension cable as I can't plug in the Brainstem in the DSATX and have a serial cable plugged into it as well (due to my layout). My idea was I would just extend the serial portion from the Brainstem using whatever wires I needed but this extension cable does exactly what I need so I thank you for that find.
        sorry - somehow missed that but believe it would be a standard pinout..... found this with a quick search........
        http://www.lammertbies.nl/comm/cable/RS-232.html#pins
          Actually when I look close at that picture on that site (which is the same in the manual) I believe it does tell me the pinout - I guess it's really only two signals from the serial port that are used - RTS and CTS which that points out on the Brainstem.
          OK so looking at that 2nd link you posted, I'm guessing I really would have had to wire all 9 pins up.
            Actually only looks like 4 - look here(other info on the acroname site about the Brainstem) http://www.acroname.com/brainstem/ha...schematic.html
            HTH
            Rick
