QUESTION about M2-160WATT AND X-TREME CARPC
  • QUESTION about M2-160WATT AND X-TREME CARPC
    HELLO I TRY TO FIX A EXTREME CARPC
    MY SYSTEM IS
    VOOM II
    M2ATX 160 WATT
    INTEL Core2Duo T5300 1,73Ghz
    RAM 1024MB DDR-II 533MHz CL4 X2
    Jetway J9F2-Extreme
    2,5" Festplatte 80GB SATA (Hybrid HDD, FlashON
    Wireless LAN USB Buffalo
    2 USB HUB D-LINK 7 USB WITH EXTERNAL POWER ( I , II )
    1 USB 4 HUB ( CONNECT TO I USB HUB )
    1 SLIM-LINE DVD+-R/RW Panasonic SLOT-IN USB ( CONNECT TO VOOM II )
    1 WEBCAMERA LOGITECH USB ( CONNECT TO I USB HUB )
    2 WEBCAMERA LABTEC CONNECT TO I USB HUB ( CONNECT TO USB 4 HUB )
    1 BLUETOOTH FOR PHONE ( CONNECT TO I USB HUB )
    1 BLUETOOTH LOGITECH KEYBOARD ( CONNECT TO I USB HUB )
    1 USB SOUNDCART MAYA EX ( CONNECT TO VOOM II )
    1 TOUCHPAD USB ( CONNECT TO USB 4 HUB )
    1 USB VGA 2.0 CART ( CONNECT TO VOOM II )
    1 USB TV TUNER HAPPAUGE ( CONNECT TO VOOM II )
    1 USB SCANNER PLUSTEK M12 ( CONNECT TO II USB HUB )
    1 USB PRINTER HP WITH BATTERY ( CONNECT TO II USB HUB )
    1 USB GPS RECEVER ( CONNECT TO II USB HUB )
    1 USB OBDII ( CONNECT TO I USB HUB )
    3 VGA USB TOUCHSCREEN (THE 3 MONITOR CONNECT TO 12V AND NOT TO M2) (1 MONITOR CONNECT TO I USB HUB AND 2 MONITOR CONNECT TO II USB HUB ) THE MONITOR HAVE EXTERNAL POWER TO 12V BATTERY.
    CAN THEY USE WITH M2ATX 160 WATT ?
    ALL THE ITEMS THEY DON'T WORK ALL TOGETHER !!!
    I'M IN THE MIDDLE OF THE PROJECT !!!
    I'm thinking about having a similar setup. You're saying these parts don't work well together?? Or not at all? What problems are you running into?
    ~The Build Process Begins~
    http://www.mp3car.com/vbulletin/newb...you-think.html
    ~The Build Process Ends~
    http://www.mp3car.com/vbulletin/show...completed.html
      MY SYSTEM IS
      VOOM II
      M2ATX 160 WATT
      Jetway J9F2-Extreme
      1. first off; do you really need all those USB devices in a carPC? LOL you won't have any space left in your car for passengers
      2. have you bench-tested this system first to verify everything works? or did you just install everything in the car assuming it would work?
      3. does the system work with just the bare minimum hooked up (no unnecessary USB devices)?
      4. the M2-ATX is probably not capable of directly powering all those devices. I see your first USB hub is a powered hub; where are you getting it's power from? are your other hubs powered as well? and if so, where are you getting their power from?
      5. some USB devices don't like being connected to hubs. these devices may need to be plugged directly into the motherboard's on-board USB ports (or through the on-board USB headers).
      F150 Truckputer [1.0] (coming soon!)
      Fusion Carputer [2.0]
      Fusion Carputer [1.0]
        1.this will be a demo car
        3.i have put everything that i say to you with out the 2 monitors back for now. all other usb works perfect without problem.
        4.the M2-ATX Works fine for now.the 2 usb hup have external powered from my car with a +12v power.
