Opus 250 Question
  • Opus 250 Question
    Hi guys. I just finished wiring my Opus 250 to the battery and decided to hook up the computer for a test. There is one thing I m confused about: where on the MB does the green and white power switch connect to? I see no double pins on the MB, just two triple pins. I am using a dell Dimension 8200 MB. If you guys could help me out that would be great.
    Scratch that guys. After I did some more investigating on the MB I realized what the issue was. Dell's power switch pins were part of a 9 pin array that ran that hard drive activity light and some other things and it was connected via a 15 pin flat cable. Strange. Anyways, I was able to isolate which pins were the power by guess and check, so I am up and running.
