Using Carnetix CNX-P2140 with Tank Circuit
  • Using Carnetix CNX-P2140 with Tank Circuit
    Got a newbie question for you folks out there. I have seen multiple varieties of Startup/Shutdown controllers and also tank circuits. As far as I can understand most of the Startup/Shutdown controllers do not directly interface with a backup battery to help keep the CarPC from rebooting during engine cranking. So my question is would this work. Installing a tank circuit (specifically the Tank EZ circuit found here: http://carpc.kyferez.com/Products/products.php?id=10) then put in place the Carnetix CNX-P2140 so as to prevent the carPC from premature shutdown.
    The reason I am wanting to do this is I am installing this system in my vehicle that I do baggage deliveries in and this requires multiple stops on any given run.
    Any help given will be GREATLY appreciated.
    Thank you in advance.
    Russell Albright
