P2140 Secondary Output not Powering
  • P2140 Secondary Output not Powering
    Finally got around to doing the install. The Primary Out is working fine with the AOpen MiniPC, but the Secondary Output is only outputting .24 volts on the multimeter, thus there is no power to the monitor. Any ideas?
    Check and re-check your jumper settings and wiring.
      Checked it many times. Everything is jumpered and wired correctly. Also had several people look into it. Will be doing an RMA tomorrow.
