need help on fusion brain 25A Relay wireing
  • need help on fusion brain 25A Relay wireing
    ok i have a fusion brain from http://www.fusioncontrolcentre.com
    and i have a 25A Relay from them
    number on the side are pcf-112d2m here is a data sheet
    http://us.100y.com.tw/pdf_file/OEG_PCF.pdf
    i have coil1 and coil 2 going to the fusion brain
    as they come pre wired to connect to the brain
    there are 2 pins labeled #4 no-cont & #3 c-cont
    on the other side is 2 copper plugs also named #4 & #3
    help...
    o can mesure voltages and i can tell pos neg
    but i would know how to wire this relay
    and help
    would be grateful
    ive googled for a few hours and found nothing exept the data sheet and its giberish to me for the most part
    ive wired a uln2003 before and can run it
    but this is higher voltage and dont want to play around to much experimenting
    in the end i want it to power a power strip or just a light bulb
    Thanks for all your help here is the answer to my question
    i hope this helps people in the future
      For Fusion Brain questions, I suggest you post in our subforum: http://www.mp3car.com/vbulletin/fusion-brain/
      I dont check the power supply area much at all.
      Looking at what you have in post #2, that is correct. Remember AC doesnt have a + and - full time. It switches at 60Hz or 50Hz if in Europe.
      1.9in x 2.9in -- 47mm x 73mm
