DIY 4pin ATX cable, how
  • DIY 4pin ATX cable, how
    Hi, i have just bought a M2-ATX, which didnt came with a 4pin atx cable.
    So is it possible to make a cable my self?
    I have 2 4pin connectors, but how should i wire them?
    If i look in to the connectors, should they just have the wires the same, like this?
    The lock mechanism in on top.
    [Y][Y] [Y][Y]
    [B][B] [B][B]
    Or can i just use a molex to 4pin atx adaptor?
    Which would be best?
    Best Regards
    Morten, from Denmark
    they sell them here.
    your diagram is correct for the wiring on the motherboard connector. I would imagine the same pins are used on PSU connector but you should test the output with a multimeter before plugging anything in.
    good luck
    F150 Truckputer [1.0] (coming soon!)
    Fusion Carputer [2.0]
    Fusion Carputer [1.0]
      Thank you FusionFanatic.
      The reason why i dont buy one, is that i need to test my M2-ATX power supply in this weekend.
      Does the M2-ATX share the same 12v rail on the 4pin atx cable and on the other cables, or does it have its own rail?
      Can the M2 Atx power this:
      Asrock 2Core1066-2.13G, underclocket to about 1,6 Ghz
      1Gb DDR2 Ram 667mhz
      20Gb 2,5inch SATA disk
      Globalsat Bu-353 USB GPS Receiver
      One or two Papst 120mm fans, to keep things cool and quiet
        1Gb DDR2 Ram 667mhz
        http://www.mp3car.com/vbulletin/faq-...my-system.html
        How about the Wiki?
          Can anybody confirm the wiring on this???
          Just got an Atom 330 mobo + proc combo, and it requires the P4 power (or so I am assuming) to power up. Have tried the method in the first post (top 2 12v, bottom 2 ground) to no avail.
          Please help?! Carpc sound card popped taking the mobo with it lol!
            Byumo,,
