Power supply requirements.
  • Power supply requirements.
    I am now in the final stage of building my second incar pc. My previous system used a standard PSU and an invertor. I now want a DC-DC power supply for my system but don't really know what I require.
    MY System;
    Via Epia Pico ITX Motherboard (1024mb ram)
    3.5" 160GB Sata HD
    I will power my screen from the cars batery though a regulator I already have.
    How much power will these draw? I like the look of the M1-ATX 90 Watt Power supply. Is 90 watts enough for my system? Is there any known problems with this power supply (i.e is it any good!).
    Any advice/recomendations would be great!
    I googled quicky and from what I read, the Pico-ITX Epia board has a single 12v input. how many amps does it draw?
    the M1-ATX is not powerful enough for your proposed system. the M1-ATX can provide [email protected] and [email protected] your 3.5" HDD will draw up to 2A by itself which would max out the M1-ATX.
    the M2-ATX-HV is the same price and can provide [email protected] and [email protected] it should be able to handle your system with plenty of power to spare.
    F150 Truckputer [1.0] (coming soon!)
    Fusion Carputer [2.0]
    Fusion Carputer [1.0]
      My Pico takes a standard ATX Power supply.
      Thanks for the info on the hard drive. I knew the 3.5" disk would draw a lot but I want to keep it as I feel they are more reliable than the laptop drives!
      I will consider the M2-ATX-HV thanks!
        Whats the difference between a HV and a normal M2 power supply
          The range of input voltage that the M2 can accept and still function.
          How about the Wiki?
            the reason I suggested the -HV was because it has the same output specs but it costs $15 less (I don't know why the regular M2 costs more... )
