Opus Power supply 90watt, spec sheet?
  • Opus Power supply 90watt, spec sheet?
    I got a opus 90watt power supply from a friend. I don't see them anywhere anymore so I assume they don't make them. Does anyone have the spec sheet or pdf file for this?
    don't see a PDF manual but looks like most all of the info is here, http://www.opussolutions.com/index.php?p=product&id=35
    Also the OPUS site lists it as Obsolete, so you are most likely correct that they don't make it anymore.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
      This one turns the mb on after only a few seconds and I dont see any jumpers to change any of the settings. ALso there is a small 3 prong plug on there that I have no idea what it's for.
      I'm checking out the link now.
