com port max voltage
  • com port max voltage
    what is the max voltage you can feed pin 8 of a serial port?
    and do any of you uses any protection to stop spikes from relays when they
    open and close
    See RS232 spec here : http://www.lammertbies.nl/comm/info/RS-232_specs.html
    open and close
    Use a snubber diode across the coil, standard thing to catch the back emf.
      most that link is over my head am i correct to believe it can take 25 volt
        In theory, yes. However in practice it tends to be more like -12 -> +12v and I'd be slightly worried about putting more than that in. In any case I would put a current limiting resistor in series to reduce the chances of any issues.
