OPUS 150w DC-DC ATX Testing
  • OPUS 150w DC-DC ATX Testing
    Hi,
    I am currently in the middle of preparing my next generation car pc. I used to have this in my car but now I am going to install it in my van (truck) for more practical reasons.
    I used to use a VIA EPIA M10000 board with the OPUS 150w just fine but it was always a little sluggish. On the new build I plan to use the board and proc out of an old Dell Dimension 2400 machine.
    So far I have the machine on a test bed with the OPUS powered up slightly awkwardly off of a normal psu so that I can test the OPUS on the new motherboard configuration. It is an Intel based 845 board (I think - no markings) with 1GB RAM and a Celeron 2.4Ghz proc.
    My question really is this... On the test bed it is working just fine. I'm actually suprised about how well it runs to be perfectly honest. However, if I overload the OPUS, will it pop or just shut down?
    The reason I ask is because I have yet to test it with the Lilliput touchscreen and a few USB devices.
    I've tried searching for this but can't seem to come across a definitive answer.
    Thanks guys,
    Paul Pitchford.
    P.S. Things have moved on here since the few years since I last visited but damn it's as good as ever! Keep up the good work!
    Ford Transit 135 T350
    1Ghz Epia M10000 ITX
    OPUS 150w
    512MB DDR
    40GB HD
    7" Lilliput Touch Screen (Powered from Opus)
    0% Completed - Used to have this PC in my Ford Focus RS for fun but now I have it in my van for work! It's awsome!
    Originally posted by paulpitchford View Post
    Hi,
    Thanks guys,
    Paul Pitchford.
    I would think you'd blow the fuse. Click on the power supply calculator to get a general idea of your pc's power consumption.
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
