Can Carnetix turn your laptop on/off?
  • Can Carnetix turn your laptop on/off?
    Can Carnetix turn your laptop on/off? I'm not quite sure what it means in the instructions, so is a second device necessary, such as this:
    http://www.mp3car.com/vbulletin/user...rn-module.html
    the P1900 and P2140 Carnetix units have an onboard relay that shorts the power button leads (same way that webmaster's auto power-on module works).
    there is no need for a second device
    F150 Truckputer [1.0] (coming soon!)
    Fusion Carputer [2.0]
    Fusion Carputer [1.0]
      Great! Thanks for the quick response. So no soldering is needed to my power switch now correct, because I just need to plug my laptop to the carnetix?
        YES... soldering the power switch leads IS still required.
        the Carnetix units have 2 wires from the "ACPI relay". those 2 wires are the switch contacts of the relay. you need to connect/solder those wires to the power button leads.
        if a docking station is available for your model laptop and has a power button, then it may be easier to solder that switch instead
          Fusion you have been more than helpful and simplified understanding this alot for me. Thank you.
            you're welcome
