Wire & fuse size for 360W psu?
  • Wire & fuse size for 360W psu?
    What size wire should I use for the Opus 360W psu? The psu itself uses 3x16awg wires for 12v input. I've got a 12awg solid copper cable (used for wiring houses) that I'm planning on using, but I'm not sure if it'll be enough. Also, what size fuse should I put in line with the battery? I've seen 20A for 150W, but I haven't seen anything said for any higher. The psu has a 30A fuse onboard; should I just use another one of those? Is there a good way to tell what size wire for what amperage, and what amperage for total input; or is it all just guess & check? Thanks.
    You should go with the same size fuse that is on the PSU, maybe a little bit smaller if you don't plan on using the psu's full potential.
    For wire size look at the 12 volt table here: http://www.backwoodssolar.com/reference/wire_size.htm
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      I am using an 8Guage wire with that psu. Nevertheless, the wire rating calls for the use of a 10guage wire @ 8feet in length maximum, or 8 gauge @ 15 feet of wire max.
      Check out my CARPC: Project Diamond Plate
      Quick Reference:
      CPU Electrical Specs
      Power Supply Calculator
      Video Connections for newbies
      Temperature Converter
      Voltage Calculator
        Perfect! Thanks Paul.
        For thread preservation, the suggested wire gauge is 10awg @ 8 feet, 8awg @ 15 feet.
        beat me to it dmand ;-)
