Carnetix 2140 outputting 14v??
  • Carnetix 2140 outputting 14v??
    After having my 2140 in my car for two weeks and working fine, I went to turn my car on to find that the PC wouldn't power on. After checking the wires I found that my primary output from the carnetix suddenly outputs 14v instead of the 20v it has been outputting! 14v isn't even an option!
    Has anyone ever seen this before?
    I'm sure it's being stupid. Hook the unit up via USB and reset it with the PSUmoni software.
      Ok, I'll give it a try and let you know how it goes.
        Same problem. I just tried resetting it. Both the PSU Moni and the multi meter show 14v output on the primary.
        For some reason the fuse just blew the other day when the system turned on. Wasn't doing anything, just turned the car on and the power wasn't there anymore. I think this thing is shot
          I'm in the same boat with mine. Sometimes it works right, sometimes it doesn't. I got about 18 months out of it.
            Greeeeat product. Lasted me a whole 2 weeks.
              You may want to try re-flashing the 1.8.3 firmware. I don't know if it'll help or not but it's worth a shot.
                sounds like a hardware problem too me since the voltage settings are done by jumpers.
                  I just decided to purchase another Carneix unit, although the next tier down. Anyone want my old one for cheap??
                    Try it if work ok if you set 12V on primary... And then you can sell it to someone who need 12V primary(For any Commell or other motherboards)...
                      About 14V is what your car battery outputs, so it sounds like the primary regulator blew. What is the voltage output on the secondary rail? Anything burnt on the PCB?
                      You might want to try what Dejan suggested, but I'm a little skeptical that it's going to work. I would test that secondary rail though, you should have regulated power (3A) coming out of that so it might be useful....unless that circuit if fried as well.
