Question
  • Question
    I want to switch from sitting to 12 volt converter 220v Can I buy a 300
    or 500 watt or 600 watt or 1000 watt On a regular computer and not
    laptop
    INPUT Power Supplies : 115v / 230v
    Current : 8A / 4A
    FREQUENCY : 60HZ / 50HZ
    If I understand your question correctly, you want to know how many watts your inverter should supply?
    The formula is Watts = Volts X Amps
    Watts = 220v X 4amps = 880 watts. You should buy a 1000 watt inverter to be sure it is large enough.
    Want to:
      Thank you, you must buy an adapter 1000 Watt
        Thank you
