Pico power supply question
  • Pico power supply question
    So for the time being my power supply is fried and I'm looking for an inexpensive replacment until I can afford something really nice. I was looking at the pico ones, but noticed they have a dc 2.5mm jack. I looked on line for more pics and ebay I noticed it plug into a power brick and into the wall 120v.
    Can I wire this directly into my car and bypass the power brick?
    Any other cheap solutions?
    Most of those require regulated 12V input, they do not regulate the 12V on the PSU. The M3-ATX does regulate the 12V and can be used as-is in the car.
      The m3 is $80. Can't I use something less expensive for temp use?
      I have a dsx12vd which is brand new, however my motherboard the epia-m10000 (something something something) doesn't use the 4 pin input. Unless there is a way to change that.
        Sounds like you could connect the car to the dsx12vd, then the output of that to one of the Pico-PSUs.
          Can I do that? That would be great! The dsx12vd only has the 4pin wire though and the pico psu has the 20 or 24pin.
            No, from the sound of it, you plug the pico psu into the mb and use the dsx to supply the needed 12V to the pico psu.
            Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
              As far as I can tell, yes, you can do that. You would need to hack up the 4-pin cable (or get another to hack up) and get a connector for the DC-in on the Pico-PSU, connect the positive wires from the 4-pin to the positive on the DC-in and ground to ground, and connect your car to the dsx12VD.
                I can see how that would work. Yellow is 12v anyway and the picopsu takes 12v input. Now I just gotta find one. I want it like yesterday lol
                  Looking at the 12vd it appears there is a .25inch spade connector that also outputs 12v. That can carry more current.
                  Plug the pico psu into the m10000 and supply the pico with power from the 12vd to regulate the supply.
                  Want to:
                    Thanks bug, I'll go that route then, but where do you see a spade connector?
                    http://images.google.com/imgres?imgu...a%3DN%26um%3D1
                      Just above the the GND, ACC, +12V terminal block.
                        Wow, never noticed that. So use that for 12v output and the black wire from the P4 (4pin) for ground then?
                          Well I said screw it and bought one off ebay for $35 shipped. Also ordered a ide to CF bootable adapter and an 8gb CF card to replace the hard drive.
                          Does anyone know if I can run centrafuse with a version of linux? I'd like to eliminate windows.
                            Check the Linux forum, but it appears that Centrafuse does not run in WINE.
                              Do you mean windows 9x?
