how does M2-ATX turn off my pc???
  • how does M2-ATX turn off my pc???
    I feel very stupid - but I've just bought one and this question came into my head....
    When I turn my ignition off, how does the M2 tell my PC to shutdown/hibernate?
    as far as I can see - the only connection to the mobo from the M2 are the power cables themselves
    now for power up I have my bios set to auto power on when power is detected.........or does the M2 do something fancy here too?
    cheers for the help guys
    Lewis
    Lewis
    If the only connection to the mobo is the power cables themselves (20pin ATX and optionally 4pin P4 connector) then you installed it wrong and the M2 is doing nothing but essentially pulling the plug from the wall.
    You need a cable from J8 to your mobo's ACPI Power Connector.
    1.9in x 2.9in -- 47mm x 73mm
      2k1T....I've only just ordered it, it will be here tomorrow.
      thanks for the reply..........whats an ACPI power connector???
      google here I come
      I'm moving from a laptop setup where by I turn it on via a pushbutton on the dash.....thats why I may sound abit slow - sorry
        The ACPI power button is that button on the dash that you're pushing. The button that tells your motherboard to turn on/off regardless of whether or not it has power. That's why when your computer is plugged in at home, it isnt ALWAYS on, you can shut it off and turn it back on later without cutting the power completely.
        2001 Mustang Convertible Worklog
        Indigo Custom Frontend (Flash/Delphi)
        Blog
        Qube v1.3 Now Available at the mp3Car Store!!!!!!
        The simplest IO controller you'll ever use!
          ah ok.....so where currently I have a 'push' button on the front of my desktop....that leads to port/plug on the mobo.....?
          the M2 will connect there instead and act as the push button to power on and off the pc??
          have I got that right?
            Yep.
            Blog
              And optionally you can connect that pushbutton to the M2, since it is in parallel. So you can do it manually or have the M2 do it automatically.
                heheheheh, how often do you talk about that j8 pin eh ,2k1Toaster??
                  I'm thinking of getting a tattoo.
