a few questions about M2-ATX
  • a few questions about M2-ATX
    Hello, a few questions about M2-ATX
    1) When connect 12+ cable to battery from M2-ATX i'm guessing that i'll need a fuse in there as close to the battery a possible? what amp fuse would I need?
    2) What is the name of or what type of connectors are used for RMT/LED/SWITCH/MOTHERBOARD ON? look like a fan (PC) connection, but just two wires.
    3) How many volts does the remote connection give out? as my amp needs 9v minimum, tested this on the amp as well.
    www.facebook.com/j666gak
    1 - Yes, use a fuse. 15A or 20A should be fine. You really should learn to calculate amperage draw to determine your own fuse needs.
    2 - Look in the manual fr our motherboard. Different manufacturers label them differently, but it is a 2-pin header, much like the pins that accept a jumper.
    3 - Don't know, but probably 12v with very low amerage.
    How about the Wiki?
