Power Supply Recommendations
  • Power Supply Recommendations
    I have a Opus 150watt from when they first came out. It's worked GREAT over the years. However I have recently purchased a new motherboard and a dual core e5200 and 4 gbs of ram. I hooked it all up and the fans started and turned off and back on then off. Then I start the car and it powered up and booted into windows.
    I need more power. I would like a power supply that acts just like my opus, but obviously need more power. Obviously something reliable and easy to set up.
    What do you recommend?
    I was thinking of something in the 250watt range. That should do it.
    BossTone74
    DSATX. You can't go wrong.
    How about the Wiki?
      Thanks! Anyone else want to chime in?
      BossTone74
        Ok, just remember you asked...
        I was suggest a dc-dc power supply... from the mp3car.com store...
        I also suggest, Hot Dogs be eaten with Hot Dog Buns.
        And ferther mor, you could take that 150watt and run it in seer-ez with another 150watt and get a 300watt supply!
        MUAHAHAHAHAHA 5:00o'clock cant come fast enough!
        How many useless post is that today? ha ha I'll quit I promise...
        Originally posted by menudude
        thank you all for your help minus the useless post by sjlucky...
          Thanks...and you were right, useless...
          Don't post anymore, you are are on Post #666
          BossTone74
            p2140
            or a new opus
            CarPc
            Project "Driver"
            Planning [99.9%]
            Parts Collected [98.5%]
            Installation & Fabrication [98%]
            Total Completion Level [96.9 %]
            http://www.mp3car.com/vbulletin/work...ct-driver.html
