issus with m2atx psu!(16 hours of troubleshooting on my pc)
  • issus with m2atx psu!(16 hours of troubleshooting on my pc)
    Hi,
    it appear that my psu m2 atx do not have enought juice for my setup....or something else maybe...
    let me explain:
    when i conenct the m2 atx psu to the motherboard(in my home with the psu hack) ...and i put a headphone into the jack of my sound card asus d2 pci....there is crackinlg...like if there is not enouf juice on the output of the sound card (it is just one outpout...the other one are ok...)
    now after like 16 hours of trouble shooting to find what was the problem....i decided to connect a 400w home psu directly to the motherboard...
    and ...no more crakling in the headphone
    i would like to know if it is the psu himself(like bad batch )....or should i change my psu because 160w isnt enought?
    and what psu i have to choose if this one is not enought powerfull(not sure)?
    my system...:
    Intel D945GCLF2D mobo
    ssd ocz solid serie
    sound card: asus xonar d2 pci
    mo-co-so case...so i wont be able to put an opus 320 w psu in the case
    (the other thing in my car was not connected when i try this in my home)
    Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
    what is powerwing the pci slot..maybe there is a way to get more power to this?
    without buying anything?
      maybe the m2 atx doesnt have the right power on the pci slot?
      is there any other psu wich has more power on the pci slot ?
        more info...when i dont use the jumper on the m2 atx..the pc do not boot....but when i palce it on any position ..it boots....(something linked to my problem?)
          The M2 like all PSUs gives its power to the mobo and the mobo splits it up the way it wants to.
          If it boots then it is fine. The M2 does have some noise issues, it is cheap. If it just happens on one sound port, then more than likely your mobo is the problem not the PSU. You did buy the cheapest PSU and the cheapest motherboard, so there could be issues
          1.9in x 2.9in -- 47mm x 73mm
            yes but when i connect an ac/dc power suply of 400 w directly on the mobo...the sound is clear on this jack...
            when i conect the m2atx...the sound is crackling
              i have the following setup before that m2-atx was able to power up fine so i think your setup should be good with m2-atx...
              micro-atx board w/ amd 2700xp
              2 sticks of ddr memory
              1 agp card
              1 HDD
              4 80MM fans
              So I would check for ground loops or maybe the 12 volt input, from PSU hack to M2-ATX doesn't have enough juice
              broom-broom-pc
              m-atx:amd2600xp:512mb:40gb:m2-atx:roadrunner:lsxvoid
                then I guess you figured out your issue, the M2.
                  i know that is the m2 atx...but would like to know if i have a crappy one...or if it is not enough powerful
                    same thing appears in my car...this is the reason i have done troubleshooting into my house..
                      Well like technostar said, it is only as powerful as your weakest component. It makes no difference if your bench PSU is 400W but doesnt put out enough on the +12v rail.
                      And there is no way for someone to diagnose a bad batch PSU from across the internet. All I can say is mine works fine.
                        ok mais le psu de 400 w a fait disparait le problème de la sortie qui ne jouait pas bien (j'ai aussi oublié de dire quelle ne jouait pas fort)
                        the m2 atx do not put enought juice..or it is just crappy...(one of the two)
                        so would like to know if i should buy another m2 atx...(it is normal that when i remove the jumper on the m2 atx , the mobo doesnt power on)(it is not a big problem..but maybe a hint to know if it is crappy)(and the psu doesnt survice to engine crank when it is not in recomended position)
                        now the problem:
                        i would like to buy the opus 320 w...but this psu do not fit in my mo-co-so case
                        i am sure my english is confusing some people here..
                          it is possible that the psu makes interference with my audio card when it is on?
                            Yeah but when you power it directly not everything is coming from the +12v rail of that PSU. When you power the M2 off of the yellow cables of the PSU, you may only be getting 100W depending on your rails and PSU age.
                            now the problem:
                            All the problems with your M2 suggest that it is bad or a fake. I know you said you bought it from mocoso or something, but these are the symptoms of the $30 M2's from china with the bad firmware and cheap components. I would buy stuff from mp3car, or direct from minibox for the m2.
                              it is written mini-box on the psu...but maybe mo-co-so bought from china a cheap one
