M2-ATX-HV No Power D945GSEJT MB
  • M2-ATX-HV No Power D945GSEJT MB
    I have installed a M2-ATX-HV power supply in my jeep. I am using an Intel D945GSEJT motherboard. I ran a + and - wire from the battery and light tested them and they are working. I ran a wire from the ACC and light tested it and it is working. When I start the car, I get no power from the 4 pin connector. The motherboard only has a 4 pin connector and not the full ATX connection. I connected a 4 pin connector from an ATX power supply and the board showed the green power light on it. With the M2 I get now power light or anything.
    Does anyone know why it isnt giving me power?
    EDIT: Forgot to add, I am running 18 gauge wire from the battery. Is that too small?
    My 2007 Jeep Wrangler Worklog
    Since Im not connecting the normal ATX connection to the board and its not starting, would I need to plug that connection into the PSU and jump it off like you have to jump a normal ATX power supply to use those rails?
      18awg is probably too small a wire.
      And you're using an ATX power supply with a non-ATX board. You need to "fool" the M2 to think it's on.
      Frankly, I think there are better solutions than a kluge job like this. others have gotten it to work, and you probably can, as well. But you're using a PSU for a job that it is not specifically designed for.
      How about the Wiki?
        What power supply do you recommend?
          I recommend reading the FAQs, where you can easily determine an appropriate PSU for your setup.
          There's a link in my signature.
          How about the Wiki?
