wiring help
  • wiring help
    Hi all,
    Finally got some items (used ... but at least it is start)... however, I need some help figuring out these power lines.
    Basic setup:
    voompc with jetway, power is M2-ATX also have an external plug for home testing ... problem is that not sure how these wires should together
    I have been downloading and reading manuals to figure this out. However, some basic concepts are still escaping me ...
    I figured I'd bother you guys here instead of blowing up parts.
    Here are pictures for the puzzle. Comments are above the pictures.
    Question:
    This is the power adapter cable. Dumb question but which wire is the ground?
    pure black or black with white strip?
    Note: molex connector from the M2-ATX ... simple enough on this side, but if I'm wrong could you point this out?
    red = positive (battery)
    white = ignition
    black = ground
    connector that plugs into the M2-ATX molex.
    should just fit on
    Ok here comes the fun part:
    1st picture is for a kill switch and the 2 is for a Y-splitter setup.
    phew!
    1st question:
    Can the white wire (12v ignition) just tag into something like the cigarette lighter plug or should I find a more sturdier power source near the key switch? I do have an available power source on my engine starter harness.
    2nd question:
    I'm been staring at the wires for a few hours now and I'm really worried about just plugging up and blowing up something. At least with a radio you just fry a fuse ... not a mobo
    what I think I know:
    red (12v) goes to battery in some form.
    white (12v) goes to lighter or some other start on power source
    black -- ground.
    what I obviously don't know:
    Which wires go where to utilize the switch?
    And
    Can I just plug the black/white black wires for the adapter to the molex from the M2?
    will need to know which is positive.
    Thanks and really sorry for the newbie stuff.
