Adding 12V AC Outlets...
  • Adding 12V AC Outlets...
    I've purchased the Tripp Lite PV375 375W Power Inverter with the intention of mounting it inside of my center console on my 2005 Chevy Cavalier. However, I read on the device that it can automatically shut off... Therefore, I have the problem of being unable to reset the device without tearing the center console out and flipping the switch.
    I don't know much (if anything) about electrical engineering so I was wondering what my options would be... Is it possible to take the switch out of the unit itself and mount it separately and if so, how would I go about accomplishing such a task?
    Yes, it is usually easy enough to take the switch out and remote mount the switch. You'll probably have to extend the wires to the switch by soldering extensions to it.
    Want to:
      I took the ends off of the unit and I see it's pretty simple. However, the wires are all soldered and I have never soldered anything nor do I even have a soldering gun and/or iron. I suppose there is always a first time for everything. Anyway, how do I know what gauge the wires are and do I need to use a different gauge for longer distances?
      Additionally, I was reading that many cigarette lighters put out about 120 watts and this unit has two AC outlets with a total of 375 watts.. Therefore, (again, based on things I've read) would I need to run a fused wire out of the back and straight to the battery? If so, how do I do this? Another thing to note, the unit has a fuse in the back of it, do I still need to run a fused wire or just a wire?
      Lastly, how do I get the wire from inside the vehicle to the battery and where (exactly) do I hook it up?
      I'm hoping to do this myself as I would love to learn about all of this stuff. However, I want to make sure everything is done properly as I don't want any fire hazards. Therefore, I would appreciate it if you could give me links to references or videos in which explains any or all of the steps above.
        The only auto shutdown seem to be low voltage (and presumably overload).
        However it just says to turn off the switch to let the battery recharge.
        It doesn't say if it will automatically recover once battery voltage recovers.
        But since you have a master on-off for it (unless you want it on all the time?!), you won't have to worry - just cycle the power.
        If for some reason you like the extra drain on batteries and don't have an on-off switch, you have its cabling fuse somewhere near the battery so just pull that and reinsert.
        In either case, you do NOT have to access or extend its inbuilt switch.
          most inverters will not auto cycle after a fault condition and will require power be removed. I would not use the cig lighter cut it off the end and hard wire it into a suitable circuit or back to the main battery just make sure to add a fuse...
          Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
          System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
          I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
            A cig socket for a >200W inverter - I don't think so!
            Besides, if you used a cig socket, why would you bury the inverter under a console etc.
            Alas I didn't see post #3 (mine was when I submitted it!?).
            But you need a big enough wire from the battery to the inverter for both +12V and GND, though the GND could be a heavy body connection (same cable size as the +ve).
            A fuse must be fitted at the beginning of the +ve cable as close as possible to the battery. (Or maybe a circuit breaker.)
            Worst case - assume 600W peak at 10V => 60A.
            Typical = assume 375W @ 12V = 32A = 35A at 90% efficiency. So maybe a 40A fuse & cable? (Does that mean 10 or 12 gauge - I work by total voltage drop so I don't use wire capacity tables...)
              The fuse in the back of the unit is a 40A fuse so I'd assume your calculations are correct.
              What would be the best way to extend the wiring to the power source? Cut the cigarette lighter off and twist together a new wire with a wire nut? Remove the factory wire and solder my own onto the device itself? Or something else?
              Also, as I asked before, how do I get the wire from inside the vehicle to the battery and where (exactly) do I hook it up? If anyone knows of any video or pictures that may help, I'd love to see them!
                Don't use the cig lighter unless you want to torch your car. They are rated for 15A (if that) and at best 20A. Even then they are not recommended for high currents. (Not even the newer Euro style MERIT equivalents handle 20A.)
                An inverter that large should have screw terminals to add suitable cabling. (Surely it isn't a hard-wired cig plug only?! If it really does 375W, that's a law suit in waiting!)
                As above, you therefore want cabling for at least 40A and a fuse to suit the cable at as close as possible to the battery (that's to protect the cable in case it shorts etc).
                I'd suggest 45A or more so you don't blow both fuses in a fault.
                Or if using less than 40A and the inverter is buried, use a 30 or 35A fuse so you can replace that rather than the inverter's fuse.
                You won't be able to use any cabin wiring for this - if it handles 40A it will be for something else (audio perhaps?).
                So drill a hole through the firewall and grommet it for the cable(s) following normal safe installation processes.
                Alternatively find an existing hole (unused plugged hole etc) and use that.
                If you can't get 40A cabling through, you may have to consider mounting the inverter externally, hence you only need twin 3-5A cables, allbethey rated for 120VAC and hence thicker insulation.
                The only alternative is to limit the inverter draw to what the cig lighter will handle (fit a 15A fuse to the inverter), or get good fire insurance (deliberate or otherwise).
                  Obligatory 2k1toaster reference about cig lighter mods:
                  RevFE
                  My Shop
                    I was looking for this when i started to read through his posts.
                    Here is my 2 cents. Number 1, run a proper line from the battery to the inverter. Number 2, is the inverter a sine wave inverter, if not you may destroy some PC equipment eventually. Never mind number 2 if your not installing a PC, I cant tell because your only asking for out lets.
                    I would never ever connect a inverter to the cig lighter, and think its a crime that manufacturers of inverters do that. Also even though the inverter is fused, you put a nicely rated fuse on the line coming from the battery, preferably closer to the battery. Why? because if you put the fuse more to the inverter and something goes wrong, all the wire in between the battery and inverter doesn't turn into a hot fiery jump rope of death that causes your car to catch fire.
                    1X Ainol Novo Flame Tab
                    4X MK808b
                    3x Perixx Touchpads
                    3x 7 inch Screens
                    1X 7 inch motorized Screen
                    1x Win 7 PC
                      Love it!
                      Though is that the lappie browning out & flaming thru under-supply?
                      The ciggie burn should be its cabling - though probably its socket and wiring to & thru the fusebox to the battery. (The fuses won't blow - what do people do when cig fuses keep blowing... Yeah - a 40A fuse replaces the 15A or 20A fuse that protects the 15-20A cable. Double current, double heat, but only one fire.)
                      They say a pic is worth 1,000 words.
                      Thanks Malcolm - you posted two.
                      Stay cool.
                      PS - that inverter claims to be PWM which infers sinewave. But at that price? (Maybe its stepped-wave output is regarded as Pulse Width and Modulated lol!)
                      It's good seeing more cig-socket wisdoms.
                      I have 150W inverters that I'll plug in to cig sockets (to grind coffee, recharge shavers or mobiles (cells) & other things I do not have 12V adaptors for. But I know my vehicle's electrics.)
                      For larger, I use Anderson connectors - typically the 50A units.
                        Originally posted by OldSpark View Post
                        Love it!
                        Stay cool.
                        i don't remember what the original thread was, but i believe that the overall idea is that the computer can draw more than the cig lighter can power-- which, if the cig. lighter was modified, would result in a large barbeque. though i guess that a partially blown fuse could cause a low voltage barbeque also...
                        i finally saved it too my photobucket account, after using it so much and getting sick of searching for it.
                        next project? subaru brz
                        carpc undecided
                          You sound as though you may have some experience with low voltage electronics. If you have installed a car audio amp successfully you can install an inverter. I always wire inverters direct to the car battery. I always use at least one fuseable link between the battery and the inverter. Be sure to place the fuseable link closer to the battery than the inverter. Be sure to use the appropriate guage wire also and no "mickey mouse" connections.
                            You're right about the PC (like any constant power load like amps & inverters above ~200W etc), but it's the power-supply that burns - eg, the car wiring & cig lighters etc that can't handle the extra current.
                            PC & inverter fuses are rated for their current consumption at their minimum rated voltage (say 200W @ 10V or 8V etc).
                            And any poor connection at reasonable current means heat.
                            A cig socket is a poor connection at 20A etc (ie, its resistance is to high).
                            Keep in mind that the heat is proportional to the current-squared - ie, Amps x Amps, eg, 100A generates 100 times the heat of 10A (which is only 1/10th of 100A).
                            Hence as Leo said - NO dodgy connections!
                            Twisting wire tends to go high-resistance even for low power and signal wiring. It's suicidal for high-current connections.
                            I have a common type green plastic 40A fuselink that is distorted with a brown inspection window thanks to a poor connection to its terminals.
                            [ Either that or it sat above 40A for quite a while, but I doubt that to be the issue since such plug-in types are available up to 80A. However most are screw in from about 60A, and after this experience, I will certainly consider screw-ins for 40A or above - else clean & good terminals probably with a temp sensor ('cos I have having to unbolt fuselinks). ]
                            Incidentally - the browned off 40A flink still works. It's still in use as either my alt-bat flink else headlight power flink (the latter is pretty stupid eh? But I have an emergency bypass).
                              Thanks for the great information guys! Leo, I appreciate your comment but unfortunately I do not have any experience. I have simply done some good, old fashioned, research before proceeding to burn up my only ride to and from class every day. hehe
                              Anyway, the information above has answered soo many of my questions but could someone guide me through the process? I'll get it started and you guy can simply correct anything I have wrong.
                              1) Cut the plug off the end of the inverter.
                              2) Extend the hot wire.
                              - How do I strip a double cable and how do I know which is the hot wire? [ View Image ]
                              - How much extra cabling should I add? Enough to reach the battery plus X (inches|feet)?
                              - How do I attach the new wiring to the old? Wire-nut?
                              - What gauge wire am I to use? How is this calculated?
                              3) Run the hot wire though the firewall.
                              4) Add an inline 35A fuse on the hot wire, near the battery.
                              5) Attach the hot wire to the positive battery terminal.
                              6) Extend the ground wire.
                              - Does this need to be the same gauge?
                              7) Run the ground wire to the metal body of the vehicle.
                              - How can I be sure it's attached to an acceptable surface?
                              8) Anything else?
                              Thanks for all of your help, it means soo much to me.
